Ujjlenyomat olvasó hiba
 Üdv mindenkinek!
Nemrég vettem egy Dell G3 3590 (G3590FI5UE1) laptopot. Szeretném megoldani a bejelentkezést ujjlenyomattal.
Feltettem a Fingerprint GUI-t https://mintguide.org/tools/257-fingerprint-gui-authorization-using-fingerprint-scanner-on-linux-mint.html, de nem találja az olvasót.
Linux Foundation (0x1d6b) 3.0 root hub (0x3)
unknown vendor (0x27c6) unknown device (0x530c)
Realtek Semiconductor Corp. (0xbda) unknown device (0x5521)
Intel Corp. (0x8087) unknown device (0xaaa)
Linux Foundation (0x1d6b) 2.0 root hub (0x2)
Előre is köszi!
inxi - Fz
Mit mutat?
inxi - Fz
#1 Azt írja hogy nem talál eszközt, és ezeket a sorokat írja a program.
Az még lemaradt, hogy Linux Mint 19.3 - at tettem a gépre.
inxi - Fz
@#3
System:
  Host: peter-G3-3590 Kernel: 5.3.0-28-generic x86_64 bits: 64
  Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia
Machine:
  Type: Laptop System: Dell product: G3 3590 v: N/A serial: <filter>
  Mobo: Dell model: 0201H1 v: A00 serial: <filter> UEFI: Dell v: 1.7.1
  date: 08/28/2019
Battery:
  ID-1: BAT0 charge: 51.0 Wh condition: 51.0/51.0 Wh (100%)
CPU:
  Topology: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP
  L2 cache: 8192 KiB
  Speed: 856 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 826
  3: 800 4: 800 5: 813 6: 815 7: 800 8: 823
Graphics:
  Device-1: Intel driver: i915 v: kernel
  Device-2: NVIDIA driver: nvidia v: 435.21
  Display: x11 server: X.Org 1.20.5 driver: modesetting,nvidia
  unloaded: fbdev,nouveau,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA 435.21
Audio:
  Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
  Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
  Sound Server: ALSA v: k5.3.0-28-generic
Network:
  Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi
  IF: wlo1 state: up mac: <filter>
  Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  driver: r8169
  IF: enp3s0 state: down mac: <filter>
Drives:
  Local Storage: total: 1.14 TiB used: 147.91 GiB (12.6%)
  ID-1: /dev/nvme0n1 model: KBG40ZNS256G NVMe KIOXIA 256GB size: 238.47 GiB
  ID-2: /dev/sda vendor: Western Digital model: WD10SPZX-75Z10T2
Partition:
  ID-1: / size: 233.24 GiB used: 19.14 GiB (8.2%) fs: ext4
  dev: /dev/nvme0n1p2
Sensors:
  System Temperatures: cpu: 58.0 C mobo: N/A gpu: nvidia temp: 51 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 273 Uptime: 1d 12h 13m Memory: 7.61 GiB used: 3.13 GiB (41.1%)
  Shell: bash inxi: 3.0.32
inxi - Fz
@#5
peter@peter-G3-3590:~$ lspci
00:00.0 Host bridge: Intel Corporation Device 3e10 (rev 07)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 07)
00:02.0 VGA compatible controller: Intel Corporation Device 3e9b
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 07)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
00:14.3 Network controller: Intel Corporation Wireless-AC 9560 [Jefferson Peak] (rev 10)
00:15.0 Serial bus controller [0c80]: Intel Corporation Device a368 (rev 10)
00:15.1 Serial bus controller [0c80]: Intel Corporation Device a369 (rev 10)
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
00:17.0 SATA controller: Intel Corporation Device a353 (rev 10)
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port 9 (rev f0)
00:1d.5 PCI bridge: Intel Corporation Device a335 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Device a30d (rev 10)
00:1f.3 Multimedia audio controller: Intel Corporation Cannon Lake PCH cAVS (rev 10)
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1c91 (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP107GL High Definition Audio Controller (rev a1)
02:00.0 Non-Volatile memory controller: Device 1e0f:0001
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
peter@peter-G3-3590:~$ lsusb
Bus 001 Device 003: ID 27c6:530c
Bus 001 Device 002: ID 0bda:5521 Realtek Semiconductor Corp.
Bus 001 Device 004: ID 8087:0aaa Intel Corp.
Igen, most először volt telepítve.
Közben megnéztem a Dell oldalát. Az olvasó típusa Goodix GF3208.
Még ezt találtam: https://www.dell.com/community/Linux-General/No-driver-for-fingerprint-scanner-Goodix-GF3208-on-Linux/m-p/6242579
inxi - Fz
@#7 Azért köszönöm a segítséget.
valami mozgolódás azért van az ügyben
https://askubuntu.com/questions/1182758/how-to-use-27c6538d-goodix-fingerprint-dell-inspiron-5490-dell-vostro-5590
A kérdés ugyan nem erről a típusról szól, de a megoldás sok típust lefed. A válaszban van egy leírás a focal változat telepítésére (ami 20-as Mint-hez passzol). 19-es Minthez át kell dolgozni a parancsokat focal helyett bionic-ra, de most nem tudom leellenőrzini, hogy ehhez megvan-e minden itt:
http://dell.archive.canonical.com/updates/dists/
meg hogy kulcs tanusítvány kódja micsoda, késő van, szemem koppan....
